Hard to get T56 into reverse??
I am having the same problem. I have no problems with any other gear but even if i shift it into my other gears it is extremely hard to get into reverse. Is this everyone else's problem, need some advise.
I am having the same rpoblem, but from a dead stop, if i put it in neutral and push the clutch back in, its also hard to get into first sometimes , i usually have to go to another gear and then back to first, reverse is a biotch too, but sometimes it goes right in smoothly, im pretty sure i have to bleed mine, because its done it ever since i took the tranny out and put it back in, must have gotten a little air in the system when i disconnected the quick disconnect from the slave
Any follow up on this? Running a T56 behind a Poncho in a 78 TA. Solid , no issues for the past 4 years and approx 10k miles. Towards the end of last season and currently, I have issues getting into reverse when engine is running. Have to stop engine, put into rev then start engine. Lockout is wired via on/off switch. No PCMs. Skip shift was eliminated during build. Could it be clutch is wearing out or slave not shimmed enough? No issues in any other gear. Trans is based on a C5R main section and Viper tail.
12" Centerforce DF clutch
4th gen Fbody master & slave w/ drilled hose. Master cyl adjusted to stop just prior to bottoming out.
Extended remote bleeder.
Andrew
Wouldn't go in. Not long after my clutch suddenly died while I was cruising. Replaced the it with a new one and reverse has been working perfect since .
