how to bleed lt1 clutch?
any1 know the procedure to bleed the lt1 clutch? i tried the helms manual way and i dont get it. can any1 explain it step by step? btw hydraulics r used.
use the search button. its the same steps as a regular ls1, except your bleeder screw is alot more accessible than on the ls1's. or you could just use a mityvac; use the search function for that too
