McLeod Master Cylinder Rebuild??
Should I hone the bore of my master cylinder before reassembly? It is a mcleod master with a 13/16" bore. Where can I buy a hone that will fit that size bore?
Its very easy, take it apart and you will see what I mean. A monkey can rebuild a master cylinder. You need to use a master cylinder hone ($5 at autozone) to smooth out the bore.
The hardest part is getting the master in and out of the car, the rebuild is simple.
