Problems after Tick master install
i took the old MC out and attached the resiuar to the new Tick and i bench bleed all the air out of the system first untill i could not push the rod in by hand all all the air was out. i installed it in the car and bleed all the crappy fluid out of the slave by the way of pup the clutch and bleeder screw. then i also mityvaced it just to make sure i had no air.
my issue is that even with the rod adjusted all the way out every gear is stick very very notchy to get into and i grind 3rd even worst then before but thats not all...now my clutch engauges right at the top of travel and slips very bad in second gear with any power. nothing else changed except for the master and if anything i would thick i would have disengauge problems if it had air in it. i cant realy drive the car because like i said it like the clutch is not engauging at all.
i ahve tried everything i could think or to bleed it and it just feels like the tick master is not letting enough fluid out of the slave to disengauge fully. help me out guys
i dont know where the air could be but if there was why would that effect me clutch engaugement?
Theres also no way that the cylinder could hold fluid in the slave unless your pedal isn't coming back to the top for some reason. With the spring on the pedal removed, the pedal will only come back up if the piston in the cylinder returns....which is a sure sign that all the fluid you moved when pushing the pedal in has now returned to the cylinder/resevoir.
A dissengagement issue would cause the grinding and notchiness you speak of, however you then have a problem with engagment also with the clutch not holding under power. It sounds to me like you have a pressure plate problem. You could always put your stock cylinder back in and see if everything works as it should again. If so, we'd be glad to take a look at the cylinder and replace it if theres a problem.
