Is my master Cylinder done?
Here's the story:
Installed a Monster level III, with a new slave, pilot bearing, lightened F/W, and I had my T56 rebuilt. I blead the slave via my hole in the floor once after installation for about 10 minutes. Not knowing what it should feel like, I drove it for about 1k miles. The petal would engage fairly low to the floor, and I would have trouble getting it into 5th gear while moving (always a grind unless you double clutch), and lots of trouble with reverse at a stop. All the other gears just felt notchy. The petal also had some play in it at the top. So, being curious, I blead it some more and viola! It felt great! It felt like a stock clutch, engaging closer to the top, gears shifting like butter! It lasted a day. Next day, same story. Blead it again and nothing.
So, I picked up a mity vac. When I first started the mity vac process I got all excited about some decent sized bubbles that would surface when my wife slowly pressed the clutch in and out. My excitement lasted about 10 minutes, because I was still getting big bubbles and the petal would go from feeling firm, to squishy at the top... back and forth. After I found a spot where the petal felt firm, I took it for a ride and nothing has really changed.
I feel like I've got a freakin leak in it somewhere, and since I've got a stock 98 master cylinder of 135k miles I am pointing the finger at that. Could it be anything else? I havent put the car in the air lately because I moved away from all of my tools.
Is it tick time?.. or time to just keep power bleeding it for an hour strait? I really don't want to drop the cash on a new master, but if thats my problem then thats what I gotta do. It would be nice to have the better shifting charicteristics associated with the tick master cylinder.
The Tick is really the way to go, it just works and pushes way more fluid.
Or you can get a new upgraded GM prebled m/c for about half.
Another cheaper way to go is to get a new non-prebled m/c and bench bleed it. Truthfully it just seems the stock GM m/c's can't really keep up with anything more than a stock LS1, LS6 clutch.
With all the new equipment you've installed and still using the stock 1998 m/c... quite frankly I'm suprised your setup even works at all.
Really? I knew the 98 mc was a but I thought it would at least be up to the task for daily driving. I supose if I've got the mac daddy of clutches then I might as well just make the whole hydraulic assy built like a beast. When I was first pricing clutches I made a big deal over how I couldnt see dropping the extra $ for a master... but I see the difference now. Eh, well I guess I better start saving for a Tick then, huh? Damn it! One more thing to get in the way of my Midwest Rear.
Any more comments?
Any more comments?
The general concenses is that 2001+ the hydraulics were updated.
The 2001+ F-bodys also used the C5 Z06 clutches. A little more stout than the pre 2001 F-bodies.
Even current brand new F-body GM hydraulics have a hard time pushing the heavier OEM LS7/LS2 clutches, let alone a clutch like your Monster Stage III.
I know it sucks having to cut into your Midwest Rear budget ... But what's the use of getting a super built rear end if you can't get the power to that super built rear end ?
