noob here please help
Old Apr 19, 2009 | 11:06 AM
fuk jdm's Avatar
Default noob here please help
Well the other day i was giving my 02 camaro ss some gas on the freeway and at the end 4th i went to let off and i couldnt get it out of 4th. so i pulled over got it out and my shifter really different. like kinda hard to move around. i cant get it into 3rd or 6th. 1st 2nd 4th 5th Reverse and Neutral are kinda hard to get it in. its not as smooth as it was. please help the noob.
Old Apr 20, 2009 | 01:42 AM
CW00BlackTA's Avatar
Start by checking your transmission and clutch master cylinder fluid levels. If all's well, then bleed your clutch.
Old Apr 21, 2009 | 10:39 PM
fuk jdm's Avatar
well even if it was that. why would that
not let me get in to just 3rd and 6th what bout the other gears
Old Apr 22, 2009 | 12:49 PM
PWND3r's Avatar
Check the trans. fluid noob.
Old Apr 22, 2009 | 01:22 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Sounds like broken. If it is some gears and not all, then its a hard part. You probably have a keyway if that is the proper term stuck in the trans.
