t-56 issues (noob)
Old Apr 19, 2009 | 04:14 PM
Scott02WS6's Avatar
Default t-56 issues (noob)
I am able to put the car in gear, let off the clutch hold in the brake and the car wont die. When I try to drive it seems like the clutch is 1/2 way engaged. At first I thought it was the hydrolics so I replaced the master and slave. Well after bleeding and bleeding I have a good firm clutch but still the same issue. It all started from when i took my car in to a shop to have a SPEC 2 installed. When replacing the slave i noticed it wasnt shimmed, so i figure that: no shim = clutch eventually failed, and my problem is ?that I need a new clutch?. I will be pulling the tranny again is there a way to check the clutch?
Old Apr 19, 2009 | 04:37 PM
slayerized6's Avatar
did you use a shim on the spec 2? can you get your car to go into gear and get moving?
Old Apr 19, 2009 | 05:13 PM
Scott02WS6's Avatar
I had a shim but i guess the shop didnt put it on, it wasnt there when i switched the slave. I can get it into all of the gears no problem, but when in gear its like i am holding the clutch pedal half way down.
Old Apr 19, 2009 | 05:40 PM
if your shim isnt there, thats why its happening. your slave is not able to push the TOB far enough to completely disengage the pressure plate. put the shim on, and your slave will be closer to your pressure plate fingers and would be able to complety engage/disengage
Old Apr 19, 2009 | 08:11 PM
Scott02WS6's Avatar
where can i buy a shim? I dont have the one that came with the clutch
Old Apr 19, 2009 | 08:20 PM
give jeremy (spec-01) a pm. hes a sales rep for spec on this board. you should of gotten a shim for your clutch in the kit. idk where you can buy one individually.
Old Apr 19, 2009 | 08:39 PM
Scott02WS6's Avatar
thanks alot i really appreciate it
