Help with taking the bell housing off
Old 04-21-2009, 04:30 PM
01 Trans-Am WS6's Avatar
Default Help with taking the bell housing off
I am trying to put my new clutch in and keep running into little stupid problems. My latest is that the bell housing is stuck to the motor. All bolts are removed from it, we tried wiggling it around to losen it, hit it with a rubber mallet, and it will hardly budge. Any help will be appreciated, thanks
Old 04-21-2009, 06:14 PM
INTENESS's Avatar
I know you said you got all the bolts but double and triple check you got the one's up top they are hard to see and get at.If thats not it try getting a screwdriver or small prybar and see if you can get it to pull away like that.
Old 04-21-2009, 06:16 PM
bearcatt's Avatar
Maybe a block of wood and a heavier hammer ?
Old 04-21-2009, 06:32 PM
NBM99SS's Avatar
If you are sure you have all the bolts out then the bellhousing is just seized on the dowel pins. Keep fighting it, itll come loose. I used a pry bar and the block of wood with hammer
Old 04-21-2009, 07:00 PM
BarneyMobile's Avatar
Prybar to get it loose than just wiggle it off. Works for me.
Old 04-21-2009, 09:24 PM
There are 8 bell housing bolts correct? If so all are out. I bet its siezed on the dowels.
Old 04-22-2009, 02:00 PM
bearcatt's Avatar
Is this the first time the bellhousing has been removed ?
Old 04-22-2009, 03:25 PM
The first time I removed it yes. I since got it off, thanks guys!
Old 04-23-2009, 06:06 AM
DiabloFormula's Avatar
Get some wd40 or zep 70 and spray it in the holes where the dowels are, then just pry gently.
Old 04-23-2009, 06:37 AM
Internet Mechanic
BlackScreaminMachine's Avatar
yea, the dowels can be a bitch. BUT they must be in there when you reinstall.
Old 04-04-2010, 10:53 PM
Beamer's Avatar
Default bell housing
hey ppl just wanted to know if u guys can help out with a quick ? i wanted to know if a probe 4cl 5speed tranny will fit on a probe gt just wanna know if the bell housing is the same thanks
Old 04-04-2010, 11:00 PM
SpaZMaN's Avatar
Wat??
Old 04-04-2010, 11:36 PM
Old 04-05-2010, 01:44 AM
mylittlez06's Avatar
coat the **** out of the dowel pins with antiseize before reassembly
Quick Reply: Help with taking the bell housing off
