Did Spec change their PP design?
Old 04-22-2009, 06:17 PM
C5kid's Avatar
Default Did Spec change their PP design?
Ok I did a clutch swap and I had a Spec 3 and replaced it w/ another Spec 3 since it held up really well for me. I got almost 40k out of it and that was w/ some pretty aggressive driving.
But when I pulled the old one out I realized that the pressure plate was completely different.
Anyone know why?
Old Spec 3 on left
Old 04-23-2009, 06:41 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Id check with Spec, they are a sponsor now. I suspect since the old design for the most part sucked. They did some R&D and figured out what works. Looks beefy.
Old 04-23-2009, 11:59 AM
SNLPerformance's Avatar
That is an O.E. pressure plate that they more than likely modified, get with Jeremy on here, he'll get you squared away.
Old 04-23-2009, 12:09 PM
bearcatt's Avatar
The p/p on the right looks like a blue painted Luk gold.
It appears to be self adjusting.
You might be able to see " Luk " somewhere on the p/p
if the paint's not to thick.
Old 04-23-2009, 01:11 PM
SPEC-01's Avatar
What part number did you order? The only SAC type plates that we offer for LS based applications are those intended for use on a stock LS2 (or similar) flywheel. This would be an SC66-2 series clutch kit for a C6 or a SC68-2 series clutch kit for a Cadillac CTS-V. Let me know what you ordered and we can proceed from there. Thanks,
