Ways to quiet down shifter noise?
Old Oct 29, 2003 | 09:45 AM
Damian's Avatar
LSX Mechanic
Default Ways to quiet down shifter noise?
Since the new combo, i'm get a good bit more noise through the shifter area. My tranny is starting to die too so it's cryin a little. Anybody use any kind of sound deading stuff or anything like that to quiet down that area and the shifter?
Old Oct 29, 2003 | 03:29 PM
kossuth's Avatar
If it is an aftermarket shifter the only suggestion I can make as stupid as this sounds is to tightly wrap the stick with electrical tape. Sounds ghetto but alot of the noise might be coming from the vibrations of the stick itself. Try that, it worked for my setup somewhat. I still had noise but it was nowhere near what I had before I did it.
Old Oct 29, 2003 | 07:42 PM
ssfiress's Avatar
i was having problems with mine rattling with the stock hurst. it kept rattling loose the 2 bolts and i was getting pissed off so i got a cardboard gasket cut it to the size of the piece that the stick slides over and cut a couple of holes for the bolts and put it back together. its been 6 months and hasent rattled yet.
Old Oct 30, 2003 | 06:53 AM
Damian's Avatar
LSX Mechanic
No problems with rattling or vibrations throught the shifter. I can hear everything thats going on UNDER the car, alone with the tranny gears movin around. Thats what I am trying to quiet down.
Old Oct 30, 2003 | 11:42 AM
BLKWS6's Avatar
get a louder radio :p
you could get some sound deadner (like dynamat) and cover the shifter hole around the base of the shifter. just leave enough room for the shifter to have full range of movement.
Old Jun 23, 2005 | 12:08 AM
ls1fbod's Avatar
normal
Old Jun 23, 2005 | 01:08 AM
highspeedspecialist's Avatar
If you want to lower the rattling sound from the base of shifter to transmission then make yourself one of those gaskets. You can buy the gasket makes paper at kragen and pepboys..
Old Jun 23, 2005 | 02:30 AM
Onyx Z's Avatar
I wrapped some electrical tape around mine... it helped tremendously. Also, if it is rattling quite a bit, make sure the stick is tightened down, the bolts on mine backed out a little bit.
Old Jun 23, 2005 | 11:30 PM
Mike K.'s Avatar
maybe some dynamatt would help you?? sounds like you need a louder exhaust to be honest.
