GMPP Flywheel...will this work?
Old Apr 27, 2009 | 10:31 PM
JamesZ28's Avatar
Default GMPP Flywheel...will this work?
Alright so I'm looking for a GMPP Flywheel for my LT1 and I found this one on Summit. It says there are none on there for a Camaro past 1992 but do you think this will work? http://store.summitracing.com/partde...8&autoview=sku
Old Apr 28, 2009 | 04:03 PM
itslow's Avatar
If you are using the LT1 T56 with the pull style clutch, you need to use an LT1 flywheel. The flywheel you are inquiring about will not work. Additionally, the one in question is a 168-tooth flywheel, while the LT1 uses a 153-tooth flywheel.
