Need help fixing my tail shaft housing??? HELP
noise/vibration At high speed's or in neutral after running the 1320. and it really only will vibrate after you let out of the gas or if you put it in neutral and cost to slow down from high speeds.
My car has never done this before. Not until last year at the track i launched the car and 2 feet after it broke the torque arm (UMI floor mounted) and sent it up into my floor (Put a huge hole in my floor) . well it killed the T/Q arm umi sent a new one to me and the drive shaft didnt look bent but i still had it dyno spun and balanced and new u joints put in as well. and i have a driveline solutions 9 with all the goodie's.
Well I think when it broke the T/Q arm that it also killed the slim and the bushing in the tail housing of my trans has anyone ran into this befor??????
Also looking at how to go about this and fix it what parts do i need and anyinfo on how to take it apart and fix it. So M6 guys that fix there own trans step on in i am all ear's
Rob.
Rob.
