clutch suggestions
Old May 2, 2009 | 12:24 PM
2001CamaroGuy's Avatar
Default clutch suggestions
Trying to decide on a clutch/pressure plate to use in my Silverado since this summer I'm removing the Auto and putting the T56 from my Camaro in it.
It's a Reg Cab/Short Bed, weighs about 4200lbs (full tank), and has 4.56 gears (with the 32" tires ~= 3.73 ratio in an F-body). The truck will have an adjustable master cylinder. I'm trying to stay in the $250-$400 range on clutch/pressure plate since I don't need super high RPM/Torque capacity. I don't drag race or side step the clutch in this truck and if I ever towed anything, it would be nothing more than a light tailor with my Camaro on it. This truck is simply my daily driver.
No matter which clutch I use, I WILL be using an aluminum flywheel (don't argue with me on this, I'm happy with my experiences). I HAVE my old Spec Aluminum LS1 flywheel that has been surfaced and is ready to go (won't cost me anything). IF I change over to the LS7 clutch, I have to buy a NEW flywheel ($350).
I had a Spec 3 in my Camaro and it was a constant issue. It chattered constantly, smoked itself on hard launches, wouldn't release above 6000RPM, etc....I hated it. NO Spec!
I really like the reviews of the LS7 clutch but again, new flywheel.
Ram makes a "Powergrip" which they rate at 550HP and a "Pwergrip HD" rated at 650HP.
Any other good clutches that might suit my application?
edit:
Been reading a bit more and in addition to the "monster" clutches, there seems to be something from TDP that is an "improved knockoff" of the Textrailia? There is also someone called "Competition Clutch"?
All of these are entirely new to me.
Old May 2, 2009 | 12:46 PM
cmb570's Avatar
Im ordering a monster 2.5 w/chromemoly flywheel for my head/cam 2000ss build. Ive heard go things about it, so wish me luck
Old May 2, 2009 | 02:59 PM
4.6what's Avatar
+1 on monster! i have a stage 3 and love it. maybe the stage 1 and 2 are just as good quality
Old May 2, 2009 | 04:15 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I doubt the LS7 will last in a truck that weighs 4200+
Old May 3, 2009 | 09:53 AM
V6 Bird's Avatar
edit:
Id run a TDP unit. At least they don't have the PRC-FW1560 Flyhweels that are JUNK!
