Just installed spec III
Old Nov 2, 2003 | 08:31 AM
JESSIE's Avatar
Unhappy Just installed spec III
I just took my car out for its first drive since the new clutch install. Spec Stage III. It chattered pretty bad in the beginning when leaving from rest in first gear. Now the chatter has stopped after 14 miles. Is this a normal thing to experience. Also I was expecting a huge difference from my stock clutch nd honestly I can't tell at all. I haven't driven it hard at all want to break in in correctly but as far as grabbing had I can't tell a difference. Let me know if any of you out there experienced the same thing. I 100% positive I installed it right I installed it over a week time span so I could take my time and check over everything again and again and I also had friends check over everything as I installed it. So, I don't know if there's a problem or I just expected more from this clutch than I should have. Sorry so long thanks in advance for any input.
Jessie
Old Nov 2, 2003 | 01:00 PM
BADSZ28's Avatar
I am in the market for this clutch. I hope you will notice a difference after break-in and at the track. They say 500 mi. then you can rip it.
Old Nov 2, 2003 | 01:11 PM
mgreen's Avatar
Sounds about right.
I didn't notice much change in feel, other than it has never slipped.
I waited for 500 miles and was at the track within a week. . . unfortunately, I have chatter now. The clutch has always managed to hold out of the hole & between shifts though!
Old Nov 2, 2003 | 10:49 PM
JESSIE's Avatar
Ya I wait and see once its broken in and on slicks. I'll post a new post after I go to the track on November 14. Thanks for the replies Jessie
Old Nov 2, 2003 | 11:59 PM
PlainwhiteZ28's Avatar
chatter? normal
doesnt grab harder than stock? bull S H I T
mine broke my instrument cluster it hits so hard!
Old Nov 3, 2003 | 01:33 PM
JESSIE's Avatar
Hey Plainwhite,
The car is losing some of its chatter as I put miles on it. I havent gotten on it hard yet waiting to break it in so I guess I really can't compare it to my stock one yet. That was my mistake. I guess I'll find out once I put my slicks on it. But as far as the clutch pedal goes it feels a 100 times better with this clutch and the updated hydraulics then with the stock. Its pretty easy to push and extremely smooth and the clutch engages pretty much where the stock one did. Thanks for all of the replies I'll keep you updated once the slicks go on. Thanks Jessie
Old Nov 3, 2003 | 02:15 PM
02redSS's Avatar
what hydraulics did you use?
Old Nov 3, 2003 | 02:47 PM
JESSIE's Avatar
Updated GM hydraulics I purchased them from Speed Inc. they come pre-bled.
Old Nov 3, 2003 | 03:05 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Jesse, I hope we'll see the benefits of the upgraded clutch at Moroso...
Carlos.
Old Nov 3, 2003 | 03:34 PM
JESSIE's Avatar
Hey me to hopefully both of us will get kicked out that night.
Old Nov 3, 2003 | 03:57 PM
Damian's Avatar
LSX Mechanic
The chatter will go away. You also have to "re-learned" how to drive the car as well. You cannot drive those clutch's like you would a z06 or ls1 clutch. It will chatter and be a PITA. You're gonna need to learn how to break your habit of trying to slip the clutch coming from a dead stop, and just let it out. It sometimes appears as though you can't drive, but you'll get used to it and it won't be that noticeable.
josh
Old Nov 3, 2003 | 05:57 PM
xaon's Avatar
Originally Posted by PlainwhiteZ28
chatter? normal
mine chattered for a little while, then eventually went away. Was a pain to drive with the 3.42 gears, became much easier to drive when my 4.11's went in.
As for grabbing, I'm in total agreement. Mine holds exceptionally well. I'm running stock 01 hydraulics with no drill mod and my Stage 3 carbon clutch holds 6600rpm clutch dumps on a 175 shot of gas. My ZO6 clutches wouldn't even hold a stock motor clutch dump without smoking it.
Old Nov 7, 2003 | 01:49 PM
matthewhogue's Avatar
chatter is normal with this clutch, you aren't supposed to be slipping it, just dumping it, that's why it's the stage 3 clutch. Keep working it and you will be good. It's a bad *** clutch, we use it on all of our higher powered cars with stage 2 heads and cam and N20 and it has never failed us yet. Been on at least 5 cars and still on those cars right now. You did a good thing putting this clutch on your car. Should have done the drill out mod while you were in there though...
Old Nov 7, 2003 | 02:28 PM
MNSS's Avatar
I broke mine in for a 100 miles an then let her buck. Never slipped once, im running heads cam intake on nittos with about 40 passes on it and about 10000 miles. You will be happy with this clutch
Old Nov 7, 2003 | 05:38 PM
camarossdn's Avatar
I have a spec stage 3 clutch on mine and I did feel a difference when I went full throttle. The only problem I have so far is that I broke my @#$% 10 bolt twice. If the chattering does not stop. I would recommend resurfacing the flywheel again.
Old Nov 7, 2003 | 08:19 PM
JESSIE's Avatar
The chatter is pretty much gone with 350 miles on it. Took it out the other night and sprayed on it and it holds pretty damn good can't wait to get it on slicks.
Camarossdn- I put it in with a new billet steel flywheel. As for your rearend problems get a 9inch.
Old Nov 9, 2003 | 06:49 PM
fast ss's Avatar
I had the same trouble with my spec ll. It works great after 20 or so miles.
Old Nov 9, 2003 | 07:34 PM
JMBLOWNWS6's Avatar
It will go away.
Old Nov 9, 2003 | 08:15 PM
fast ss's Avatar
yea but, you will hear a little chader for alittle bit its just the nature of the beast.
