Pro 5.0.....Is it broke?
What's up. Is that white ball suppossed to be loose or able to come off the bottom of the shifter? I've obviously never taken the top of the shifter off before. In every picture I see of a pro 5.0 shifter, that cup looks snug. What kind of lubricant should I use, if any, and where? Thanks.
I can barely tell from that small picture, but I'm assuming you're talking about the white plastic shifter cup on the bottom of the shifter??
If should come on an off easily, it just sits in the shift rail inside the transmission and acts as a bushing for between the shifter ball and shift rail.
So does the bushing move with the shifter, or does the shifter move around in the bushing? I'm sorry if I'm annoying, I just want to fully understand it's purpose. I'm having notchy feeling shifts that have me digging.
The bushing stays put in the shift rail, and the shifter ball moves in the bushing as you move the shifter. It should fit snugly into the bushing, but not too tight.
