t56 lt1 vs ls1
Old 05-12-2009 | 10:55 AM
dvk678's Avatar
Default t56 lt1 vs ls1
I think it has been clearly stated that LT1 transmission will not bolt to the LS1 motor. What I would like to know if replacing the bell housing will make them compatible.
I am sure there is someone out there that know the answer.
Thanks you
Old 05-12-2009 | 12:01 PM
thesource's Avatar
You need to change the input shaft, front plate and bellhousing for it to work as long as your unit is the 2.66 ratio transmission.
Old 05-12-2009 | 01:55 PM
85MikeTPI's Avatar
Bellhousing, Midplate, Input shaft all have to swapped between the two.. Mixing/matching will not work.
Old 05-12-2009 | 03:03 PM
dvk678's Avatar
Understood. Thanks for the help
