Needing a clutch...suggestions?
Well I have a 02 bolt on SS with mods in sig, plus a UDP. Recently when I get on it, the pedal likes to stick to the floor, so I figured the LS6 clutch has seen its better days because of the mods on the car and it not being able to support the power....or maybe there is a problem somewhere because the clutch has less than 17000 miles along with a rebuilt tranny... So what would be a good clutch kit for my mods? I heard our cars don't like lightweight flywheels, is this true? I dont want to spend over 500, and I dont plan on putting heads and cam in for awhile, so it doesnt need to be extreme, and I hate soft clutches, I like it when my wife doesnt want to drive it!
ive been hearing alot of good things about the ls7 clutches, mine is doing the same and thats what im considering. i just done the drill mod and bled the fluid and it help alot though...
www.monsterclutches.com
Check out the clutches on the site and give us a call here at the shop, we've got a clutch that fits your description exactly and we can get you taken care of!
Steve A.
SNL Performance/Monster Clutch Co.
817-750-2000
Steve A.
817-750-2000
If you don't want to spend more than $500 then your choices are very limited. I have heard many good things about the LS7 clutch. I run a used Textralia and I love it but new the clutch is almost a grand.
It sounds like you are having the same problem I was having with the clutch pedal sticking. I would highly recommend upgrading the hydraulics. This is where most of our trans problems stem from, it's a major weak point in our cars. I installed my Tex, Tick adjustable master and remote bleeder line at the same time. It is insane how well the car drives. If you can, do it right the first time.
https://ls1tech.com/forums/manual-tr...k-mc-pics.html
