Grinding issue from 1st -2nd after pulling the tranny
Old 05-17-2009, 10:10 AM
BlueStreak362's Avatar
Default Grinding issue from 1st -2nd after pulling the tranny
i recently changed the rear main in my car, when we were pulling the tranny, we had a hard time trying to remove the line going to the slave cylinder. Now that its all back together the trans shifts fine up until about 5500, when i try to grab 1st to 2nd like i did before it grinds very bad. We originally thought possibly the fluid might have played a roll(seemed very thick and was for "mercon and dexron" not dexron 3 specific. So i went back and baught mobile 1 75k + dexron 3(only dexron 3 avail) my question is what could be causing the grinding? possibly that line is messed up? MC not bled enough? Thanks
Old 05-19-2009, 01:03 AM
greysteel_M6's Avatar
Probably the clutch is not fully disengaging, try bleeding it some more.
