Normal Clunk?
I get a nasty clunk on 5th and 6th gear upshifts IF I release the clutch quickly. Also get a clunk pushing the clutch in quickly or releasing quickly when rolling in 1st or Reverse in a parking lot. Also get a clunk moving the shifter into first when coming to a stop. The clutch also chatters when coasting in first or reverse.
Any help is appreciated.
Well I ordered a Tick MC and I figured I would swap my slave as well. I drop the trans to find that there was play in my input shaft. I am now in the process of rebuilding the whole trans even though it was done previoulsy. It seems that improper preload/endplay is the culprit.
Another tidbit that I haven't mentioned but didn't think it would cause this - I did not bleed the clutch after installing the slave and new clutch. I tried. I stuck the mighty-vac cranked it up to 15in and pumped the pedal but no bubbles came out. Maybe its got air in there causing this?
