?'s for pro 5.0 users
Old May 24, 2009 | 07:52 PM
blu byu EH's Avatar
Default ?'s for pro 5.0 users
My damn shifter handle bolts keep coming loose over time. I have loctight them. Is there anything else that I can do to keeps the bolts tight. This sucks because every time this happens and it gets loose I'm always racing someone and miss a f**king gear.
Thanks
Old May 24, 2009 | 07:57 PM
ttranssam's Avatar
almost 10k on mine and no problems
Old May 25, 2009 | 11:07 AM
97pontta's Avatar
What strength of loc-tite are you using? Do the shifter handle bolts have the lock washers on them? I've had mine for about 5 years and has never come loose with no loc-tite. Also be sure to clean the bolt and threaded hole very well before applying the loc-tite for best results, I typically use brake cleaner or another degreaser/cleaner before applying loc-tite.
Old May 25, 2009 | 03:09 PM
LS1-450's Avatar
You could use epoxy. You'd just have to heat the epoxy w/ a torch when you want to remove the bolts. I use blue loc-tite w/ no problems. Red is stronger, but a 5 minute epoxy will hold it 'till you heat it for removal.
Old May 25, 2009 | 04:22 PM
blu byu EH's Avatar
I used the red loc-tite before and tighten the **** out of it. I did the same thing to day.
It does have the lock washers on the two bolts.
Thanks guys.
Old May 26, 2009 | 07:01 AM
97pontta's Avatar
That does seem a little odd that it still comes loose. When the shifter handle is off are the mating surfaces of the shifter and handle smooth and free of burrs? If the two surfaces were not setting completely flush when bolted up that could cause them to loosen. Hope you get it figured out.
Old May 26, 2009 | 08:52 AM
ghettocruiser's Avatar
Lock washers with a dab of BLUE loc-tite. Ive removed and replaced my bolts half a dozen times easy and they stay tight as can be without re-applying loc-tite. Never an issue. Did you partially strip the threads trying to make them too tight at some point?
J.
Old May 26, 2009 | 06:02 PM
blu byu EH's Avatar
IDK, the motor and trans move a lot. I have a lot of lope
QUOTE=ghettocruiser;11655828]Lock washers with a dab of BLUE loc-tite. Ive removed and replaced my bolts half a dozen times easy and they stay tight as can be without re-applying loc-tite. Never an issue. Did you partially strip the threads trying to make them too tight at some point?
J.[/QUOTE]
I don't think the threads are strip. Thanks for all the help guy's
Old May 26, 2009 | 07:55 PM
Bouvs's Avatar
this is what I did and although I haven't put my car through the gears yet I'm confident its not going to come loose on me.
I used overlengthed bolts with red loctite and lock washers... with the bolt sticking out through the other side I then used a self-locking nut on the ends and tightened the bolt and nut against eachother. If that doesn't hold it in place I don't know what will.... good luck.
Old May 26, 2009 | 10:26 PM
SELLSZ06's Avatar
how bout some plastic washers too ?
Old May 26, 2009 | 10:29 PM
SELLSZ06's Avatar
or... dont know how you call them but those washers that are split and you squeeze them as they are tighten
p.s I run a 5.0 never had a prob like that. hope this helps a little
Old May 27, 2009 | 09:16 PM
blu byu EH's Avatar
THIS IS A DAMN GOOD IDEA. I'M GONING TO TRY THIS
I don't get it.
Old Jul 27, 2009 | 02:19 PM
blu byu EH's Avatar
Update: well after this last time I posted I just loc-tite the $h!t out of the bolts and went racing this past Saturday night and the mother f'er bolts came loose AGAIN while I was doing a rematch on the same car last time I tried racing and the bolts came loose !! And to make the matters worse I have air in my master cylinder and I couldn't powershift @ WOT nor could I granny shift WTF. I'm going to get longer bolts and get put like five nuts on it.
Old Jul 27, 2009 | 08:04 PM
mrhzk35404's Avatar
I know you said you have the pro 5.0 but what type of stick do you have with it?
Old Jul 27, 2009 | 08:07 PM
blu byu EH's Avatar
The one that comes with the shifter.
Old Jul 27, 2009 | 08:34 PM
SHovV's Avatar
no probs here. sorry cant help
