ls3 clutch flywheel fit ls1?
Old 05-29-2009 | 01:18 AM
erollinc's Avatar
Default ls3 clutch flywheel fit ls1?
will an ls3 clutch and flywheel fit my ls1?...... would a t56 bellhousing for that same corvette work on my camaro ls1 t56 setup??....... only asking cause I may be able to get these parts fairly cheap
Old 05-29-2009 | 09:01 AM
erollinc's Avatar
after some more searching j thnk the clutch pp and flywheel will work but the bellhousing will not..... can anyone confirm?
Old 05-29-2009 | 01:18 PM
Hugger Z's Avatar
If the LS3 clutch is similar to the LS7 clutch, yes they will bolt up. I don't believe the bellhousings are similar though. Corvette trans are in the rear at the axle so that is a totally different set-up.
