Pro 5.0 install
Old Jun 7, 2009 | 10:45 AM
DarkJuggalo's Avatar
Default Pro 5.0 install
just wanted to say very easy install i love the shifter feels really tight, used the pro 50 stick with about 1 1/2 inches cut off just enough thread to get a shifter on. need to adjust the stops a lil more but awesome shifter!
Old Jun 7, 2009 | 11:42 AM
sixxty7's Avatar
i was thinking of doing this. either upgrading too the 5.0 or hurst billet. i have the factory hurst. as for the 5.0, if i do this will i be able to use the stock boot and ****? also, is there a noticable between shifters? enough too justify the cost?
Old Jun 7, 2009 | 11:43 AM
sixxty7's Avatar
pics?
Old Jun 7, 2009 | 06:35 PM
i used everything that was originally on it as far as boots and shift ****. it sits about an inch lower than factory but i also hacked as much off the pro 5.0 stick as humanly possible barely enough to thread haha. i will try to get pics tomarrow. and yes well worth it. much tighter and positive engagement feeling on shifts.
Old Jun 9, 2009 | 01:56 PM
no pics yet but hopefully this weekend i can get some. got the bump stops adjusted correctly now, i wish i had done this mod sooner
Old Jun 9, 2009 | 02:01 PM
TORCHD 02 TA's Avatar
Here is what the pro 5.0 looks like installed
Old Jun 9, 2009 | 04:49 PM
sixxty7's Avatar
looks good. did you modify the shifter in any way? what i am getting at it is the same height of the factory hurst?
Old Jun 9, 2009 | 04:55 PM
I cut the pro 5.0 handle down. I think i counted 10 threads and cut it off. I think total was aobut an 1" or a little bit more
Old Jun 9, 2009 | 07:39 PM
mrsracing's Avatar
I recently had a Pro 5.0 put in and cut down and like it. I wouldn't change back and may have trouble now with a stock shifter after getting use to this. The only dislike is there is a slight bit of noise at higher RPM's.
