What did i break?
Old Jun 12, 2009 | 10:23 PM
ohioz's Avatar
Default What did i break?
So got my new mickey radials on tonight and headed down to the track to try them out. Made a few passes and the track was hooking great. So my last pass i decided to give it hell and dumped the clutch at about 5500-6000. Now the clutch doesnt disengage. Pedal feels the same and there is no noise coming from the bellhousing, plus i even drove the car home. (about 45 minutes) i just have to start the car in first gear to get it going. Im not going to be able to look at it until next week so thought someone might have a thought on what it might be. Oh and its a spec stage 3+ ive had it in the car for about two and a half years now without the first problem until now.
Old Jun 12, 2009 | 10:33 PM
HASTINGSRJ's Avatar
may be the slave.....
Old Jun 12, 2009 | 10:38 PM
ohioz's Avatar
idk its not leaking and the clutch pedal still feels great
Old Jun 13, 2009 | 07:29 AM
Gen414's Avatar
Are you saying the tranny shifts fine? I mean, you say you drove it home, but yet you say the clutch does not disengage, but pedal feels great. So, can you go through all teh gears just fine?
Old Jun 13, 2009 | 09:43 AM
ohioz's Avatar
yeah sorry forgot to say the transmission is faceplated and still shifts fine. I have to shut the car off put it in first gear then restart it to get going but once im going i can shift it because its faceplated
Old Jun 13, 2009 | 06:44 PM
ohioz's Avatar
Anyone?
Old Jun 20, 2009 | 05:19 PM
ohioz's Avatar
so just pulled the tranny out and the clutch looks fine. I took the slave off the tranny and hooked it back up to the master and pushed the throwout bearing all the way down while a buddy pushed the clutch in and it only pushed out about half way on the shaft that it rides on. So is it supposed to push all the way out or just half way? also the input shaft was bent as well so that might have something to do with it too but any input would be greatly appriciated.
Old Jun 21, 2009 | 02:57 AM
ZachsBlack94Z28's Avatar
i dunno steve......i hope it doesnt have to go to liberty for another 6 months
Old Jun 21, 2009 | 09:15 AM
ohioz's Avatar
Zach its Golen heads, quit calling them golden lol.
Old Jun 21, 2009 | 07:52 PM
I changed my mind BTW... thought you wanted to work on that thing today?????
Old Jun 22, 2009 | 07:44 AM
ohioz's Avatar
Dont change heads because you cant spell the companys name
You never called so i just thought you were busy.
Old Jun 22, 2009 | 03:10 PM
I would rather have the AI's... not because i cant spell.. Just let me know when you wanna work on it. i Just got off the phone with jeff and im going to have my bumper painted and factory hood for pretty cheap. Im just going to drop the car off over there before i have surgery its not like im going to be driving it. BTW your a DICK
Old Jun 22, 2009 | 05:03 PM
SPEC-01's Avatar
If the input-shaft is bent it could easily impact the way the clutch releases (the disc is likely hanging up as a result). If the slave has nothing to contact to limit its travel it will generally extend fully. It may require pumping the pedal a bit, especially if the fluid is aerated...but be careful that you don't over-extend the slave because then you are going to be replacing it whether you want to or not. Let me know if you have any further questions. Thanks!
Old Jun 23, 2009 | 08:52 PM
Here is the imput shaft that we pulled out of the trans today...not only is it bent but there is some teeth mising on 4th gear...FTL sorry for the bad cell pic
Old Jun 23, 2009 | 10:00 PM
mxhockeydrummer's Avatar
wowo. How much RWHP and Torque did that?
Old Jun 24, 2009 | 05:28 AM
The car made somewhere in the 430 range
Old Jul 3, 2009 | 09:45 AM
what do you know steve??? waiting on liberty hmmmm what will it be this time ??? 12-13 weeks?? hell might as well be the rest of summer. factory imput shaft = fail
Old Jul 3, 2009 | 09:52 AM
thesource's Avatar
Thats what happens when you have an aggressive clutch and drag radials. They are hard on manual transmissions.
Old Jul 4, 2009 | 04:07 AM
yup but they are sooooo much fun to race
Old Jul 17, 2009 | 04:26 AM
well me and steve (ohioz) pulled the clutch today and found that the clutch disc had welded itself to the flywheel. 1st time that we have ever heard of it.. has anyone ever heard of this ???? oh well looks like its going to get a new spec lol
