Ever try and drive in 6th gear at 35mph?
Old 11-10-2003, 05:09 PM
mrgto's Avatar
Default Ever try and drive in 6th gear at 35mph?
I have tried it. Have you? Describe your experience. Thanks.
Old 11-10-2003, 05:29 PM
mrgto's Avatar
Also, you think 91 octane would have a significant improvement over 87 when doing this so as not to reduce timing and give the motor more power?
Not trying to be a retard but just trying to disprove a pathetic theory someone else on another board has. Thanks.
Old 11-10-2003, 06:58 PM
Dope's Avatar
I've accidentally shifted into 6th at 35mph (and probably slower) before. Stupid Pro 5.0, worst shifter ever (was going for 4th).
Nothing happens (including you moving anywhere quickly), though the interior vibrates like crazy (poly trans mount, it never vibrated that bad before it).
Also, higher octane could and would definitely reduce the chance of KR (if KR is a problem, and it's not false).
Dope
Old 11-10-2003, 10:19 PM
skippytheloon's Avatar
never driven below 92 octane...but,
depends on how much throttle you give it:
>none or *very*little=nothing really happens
>half to full throttle=very,very bad shudder without any acceleration
What's the theory? I bet it's that the rear will break when the shift is at WOT! huh,huh?
Old 11-10-2003, 10:58 PM
hawaiiboysz's Avatar
wouldnt that be luging an engine I think thats a bad thing
Old 11-10-2003, 11:13 PM
Brains's Avatar
It's not that bad... then again, 4.11's help out considerably
Old 11-11-2003, 02:08 PM
z98
z98's Avatar
Not bad on 3.73's either. No vibration or anything. If I had the power, I could smoothly pull from 30 mph to 240 mph.
The Mclaren has what 650 hp? So I'm only about 300 away!
Old 11-14-2003, 10:37 PM
verbs's Avatar
I've done it before, and yes the engine lugs, the car shakes a bit, but you also get a ton of knock retard. It pulls fine w/o surging even w/ a mid size cam like mine.
Old 11-15-2003, 01:20 PM
z98
z98's Avatar
Why are you running 87 octane?
Do you not like your motor or something?
Old 11-15-2003, 08:46 PM
99 Black Bird T/A's Avatar
Received 1,456 Likes on 1,010 Posts
LS1Tech 20 Year Member
My car can easily pull 6th at 45 mph. I don't do this because as I understand it's really not good for the engine.
Old 11-18-2003, 09:50 AM
z98
z98's Avatar
The GM manual recomends you shift into 6th gear at 55 mph I believe for maximum fuel economy.
With 4.10 gears, that is about 20% more gear reduction, which comes out at... suprise suprise:
45 mph!
Do you think GM would recomend something that wasn't good for your engine?
Old 11-18-2003, 08:25 PM
mjf454's Avatar
I am still in second at 45mph
