why does my flywheel not fit onto the crank?!
sorry guys forgot about this thread but heres the update. Ive got it on but had to use a dremel to take off a bit of material to get it. now it fits perfectly. I ran into serious trouble with bolts though. turns out my new crank has slightly different size threads than stock and when i forced on the flywheel by turning the bolts i was threading in too big of bolts into the holes. ended up taping the threads and getting new bolts. got the flywheel on and bolted it in. the bolts threaded in but werent real easy to turn. anyway got everything torqued down and now just realized i needed to install the pilot bearing. Doh!
