94 Slave/Master Install Info Needed
Old Jun 20, 2009 | 11:47 AM
Rick804's Avatar
Default 94 Slave/Master Install Info Needed
Has anyone had the misfortune of trying to fit the master cylinder on a 94? The god damn brake booster is in the way. Can I remove that? Any suggestions please. I am stumped at this point
Old Jun 21, 2009 | 12:56 AM
Rick804's Avatar
Problem solved. Sold the car for 200 dollars. Just kidding!!!! I did figure out a very easy way to do the job though. I threw away the stock U-Bolt that holds the Master into the firewall and I used two bolts instead. Way easier that way for some reason.
By Brett Foote | 2026-06-04 05:00:17
