Pilot Bushing Vs. Bearing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I've used both. With the bushing you'll get more noise and vibration. The bearing is much smoother. I tried a bushing because my previous bearing had just blown apart. I used the bushing for about 30K miles and switched back to a bearing and have been much happier since.
Pilot bushings are nothing new. They have been around longer than I can even say for sure. Pilot bearings started showing up in the mid 80's and the factories have been using them every since. They last longer in OEM applications. When they do go down, it damages the tip of the input shaft of the unit and usually requires a new gear to be installed. A pilot bushing does not last as long but will not usually tear up the pilot tip on the input shaft. Pilot bushings are easier to remove in most cases while bearings usually have to be cut out or require a special puller to yank them out.
In the end, I would say both have their pros and cons. Personally I prefer the bearing over the bushing as long as its used properly and changed every time you service the clutch.
My stock pilot bearing killed the input shaft on my tranny. $1280 rebuild ![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
I went back with another pilot bearing... but only because I didnt know about the magical powers of the pilot bushing. Go with a bushing and forget about the possibility of a bearing turning into a mini lathe
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
I went back with another pilot bearing... but only because I didnt know about the magical powers of the pilot bushing. Go with a bushing and forget about the possibility of a bearing turning into a mini lathe![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
The pilot bushing or bearing is a passive unit and should not have any load put on them...just center the tip of input shaft. Both are "wear" items and need to be replaced with clutch.
as far as which one is better...GM & Tremac have found the bearing as better which is why that is the OEM install. IMHO either will work but again failure of that part is caused by issues with the tranny, typically.
Input shaft failure... probably. The pilot bearing turned to dust, literally. When I took the trans off there was black dust everywhere. I thought, wow, this stock 132k mile clutch must be toast! It actually looked like it had 20k more miles on it. The trail of dust lead right to what used to be a pilot bearing.
Eh, 5th gear was toast anyawy, according to the man that rebuilt it for me. Now that I think about it... I seem to remember him saying that everything else looked good inside my trans, to include the input. I think this could have been some sort of strait pilot bearing failure.
My only real regret is that I was in a major hurry to move and I didn't have time to get Tick to do the work. I would have gotten some beast parts then![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Their master cylinder is bad ***, if I might add.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
