Accidently hit reverse when going into 5th
You can get any parts needed for it from Tick Performance.
I agree with bigmike, I think it would take some serious excitment to bang it into reverse. I myself have slammed it over there into 5th and never had a worry. Just get rolling about 10mph and try to shove it in reverse, just don't let the clutch out, I have tried and never been sucessful
I wish I had a good pic of the Gear to post up..I just tore mine down to re-build it. Basically the Brass Synchro attempted to catch the Gear as it should, but everything was spinning so fast forward that when it tried to engage that Reverse Gear on the Main Shaft that happened to be spinning in the opposite direction(that's how it works, it has one extra gear between the Mainshaft Gear and the Gear on the Countershaft so it spins opposite) it tore the Reverse Gear Engagement Teeth and the inner Teeth on the Slider to ****.
The Teeth are supposed to be pointed on the Gear and the Slider(look like this ^), but instead they were completely squared off, as in both sets of teeth looked rectangular. That is why for me Reverse was so hard to engage, none of the Teeth would line up unless I held it grinding for a sec then it would slide in, and most of the time pop out.
It is possible to grab Reverse at that speed..you would have to hold it there grinding for a few seconds to allow the Countershaft and Clutch to completely stop moving forward and then it will get into whatever is rest of Reverse.
I don't know what would happen then but I bet it wouldn't be pretty.
Me personally I won't try to speed-shift 5th anymore..just let it slide in.
i was doing a whole shot a couple months back and when into 5th HARD never actually engaged into 5th so i immediately let off and pulled over, went through the gears and all up top gears (1,3,5,R) were hard to go into
i still have trouble going into them from time to time, but nothing major- basically it feels like it clicks into gear when i know i didnt push it far enough, and if i were to let the clutch out (instead of just putting muscle into it and pushing the shifter into gear) the tranny grinds until i push the clutch back in.... this only happens about once every couple of days, but it still happens- maybe i damg the syncros or the shifter?
