Help input shaft locked up
Old 07-18-2009 | 05:03 PM
fash00's Avatar
Default Help input shaft locked up
Looking at trading some parts for a t56 that the input shaft is locked up on.I know it could be a number of things causing it but wat is most likely causing it?
Old 07-18-2009 | 05:11 PM
thesource's Avatar
If it will not turn, chances are its trashed from lack of oil.
Old 07-18-2009 | 05:25 PM
Gen414's Avatar
Well, as tehsource said, could be lack of oil. Can you tell us HOW/WHEN it happened and what you were doing. You say input is locked up, so I am taking it you removed the tranny. Did you drain teh oil? if so, how was the level?
Old 07-18-2009 | 07:55 PM
fash00's Avatar
I dont even have the transmission yet its one im looking at getting.Thats why im tryin to figure out what it is before i decide to get it
Old 07-18-2009 | 09:12 PM
thesource's Avatar
Unless its super cheap, I would pass on it. Gears for the T56 can get expensive in a hurry.
Old 07-19-2009 | 11:29 AM
Gen414's Avatar
That is one I would probaly pass on, as by the time you end up putting parts into it, you could have saved time (and probaly money) picking up another one.
I know it can be tempting because you are probaly saying, well, I only have to come up with a few bucks for this transmission instead of "X" more for a good one. BUT, I would try and keep looking, unless it was very cheap.
