what could be wrong?
Old Jul 22, 2009 | 01:13 PM
onebadZ28's Avatar
Default what could be wrong?
I decided to change the tranny fluid in my car yesterday before i take it to the track tomorrow, and after i got everything buttoned up i took it for a spin around town. well on the way home i done a high speed run 1st thru 4th and my transmission grinded going into every gear but only at high rpms. The fluid that i used was castrol ATF because that was all advance auto had in stock other than the advance auto brand. So today i called around and found an auto store that had mobil 1 atf synthetic. i went and pick up four quarts. drained the castrol put the mobil 1 in and took it for a spin hoping to have cured the problem, but it's still there so i freakin out like what the hell my tranny worked fine before i changed the fluid now that i put new fluid in it, it grinds now. so if anyone can shed some light on the subject it would be greatly appreciated
I've been reading some stickies, is it possible that air could be in the system and causing this problem? If so how do i go about bleeding the system?
Old Jul 22, 2009 | 04:19 PM
Gen414's Avatar
Well, doubtful air got into the system by just changing the fluid. What I would like to know is, BEFORE you changed your fluid, when was the last time you went through the gears like that? Reason I ask is, you COULD have another problem, and just not realized it because you have not shifted the tranny like that in a long time, and just changing the fluid is a coincidence.
Old Jul 22, 2009 | 06:28 PM
onebadZ28's Avatar
well, i go thru the gears at high rpms frequently, i done a few high rpm shifts on the way to get the tranny fluid, and it shifted fine. but now it seems i put new fluid in and messed my tranny up lol that seems *** up for some reason. This sucks real bad because myself along with several other f-body owners are going to the track tomorrow, and it looks like i'll be in the stands watching and wondering what the hell is wrong with my car
Old Jul 23, 2009 | 08:41 AM
onebadZ28's Avatar
anyone have an idea of what the problem could be?
Old Jul 23, 2009 | 09:02 AM
Gen414's Avatar
Does it do it if it is cold, or only after it warms up? Did you notice if your slave line is routed/closer to the exhaust/headers? Could be heat related...
Old Jul 23, 2009 | 11:41 AM
onebadZ28's Avatar
with a little more driving i'll take note of when this occurs most often whether warm or cold. right now i'm in the process of bleeding the clutch. becuase the other night me and my buddy where riding around and i rev'd the car up pretty high sitting still when the clutch pushed in and he said he seen my speedometer go up to like 20 mph. this was before the fluid change. is this a systom of the clutch not fully disengaging? If so why would this occur after the fluid change? I do have long tube headers on the car, but this problem just started after the fluid change. As far as the fluid lines go i've never moved them or re-routed them in anyway.
Old Jul 23, 2009 | 05:24 PM
onebadZ28's Avatar
well i finally got through bleeding the hydro system, and now my clutch pedal is soft up top, and then starts to engage about 2 to 2.5 inch off the floor what the hell i barely can even drive the thing let alone powershift like i would at the track so what now do i need a new master cylinder come on guys help me out.
Old Jul 24, 2009 | 09:10 AM
Gen414's Avatar
OK, let's do this, one thing at a time.
Let's bleed your setup:
Top off reservoir. Put car up on jackstands. Have your friend hop in drivers seat. You under the car (sorry ) Have him apply pressure to pedal, you crack teh slave bleeder open, and right before pedal gets to floor, close bleeder. Have him release pedal. And do it again. After 3-4 times of this, check reservoir. Top off if necessary. Do these steps until you have a nice firm pedal/no more air spitting out bleeder.
About your tranny fluid....you sure you have ENOUGH fluid in? Are you filling through the "fill hole" or shifter?
Old Jul 24, 2009 | 09:20 AM
the_merv's Avatar
Veteran: Air Force
That's just the signal voltage bleeding over in the gauges. If you saw the internals of the T56 you would see that the Speedo Sensor Reluctor Wheel is on the Output Shaft and if the car is still, it's still.
Old Jul 24, 2009 | 03:22 PM
onebadZ28's Avatar
ok i'll go and bleed the system again tomorrow. As far as the tranny fluid goes i filled the tranny till fluid dizzled out of the fill hole. The tranny held right at 4 quarts of oil. also when i took the car for a test drive even though the pedal was engaging 2 to 2.5 inch from the floor the tranny only grinds while trying to shift into thrid gear at high rpms instead of all gears. once i parked the car from being fed up with it i just started pumping the clutch pedal, and then the pedal feels almost normal it's starting to engage where it use to, but i have not drove it yet to see if it still grinds. should i be giving tick-performance a call?
Old Jul 25, 2009 | 09:08 AM
Gen414's Avatar
OK, so now it only grinds going into 3rd upon "high RPM's"?? If that is the case, you have a synchro/blocking ring issue, more than likely. Could be damaged key or Fork Pad, or other, but I would lean towards synchro/blocking ring.
Old Jul 25, 2009 | 10:02 AM
onebadZ28's Avatar
what causes keys, fork pads, syncros etc to go bad? would i need a complete rebuild to get just these parts fixed? just some curious question that i have. I plan to get a rebuild strength package to handle the future upgrades that i do anyway. i just hate this had to happen at such an unexpected time, but i guess that's the way it goes lol. you got to pay to play.
Old Jul 25, 2009 | 10:20 AM
dragonrage's Avatar
What kind of Castrol ATF? They have lots of different ones.
Old Jul 25, 2009 | 02:04 PM
onebadZ28's Avatar
Castrol atf for high mileage transmissions non synthetic
Old Jul 25, 2009 | 04:39 PM
Gen414's Avatar
Yes, you can JUST replace the 3rd gear synchro if so choose (is actually 3/4 setup, but you don't have to do 1/2 5/6, etc)...if you want to to save money.
Would I recommend that? Not really...yanking a tranny out, tearing it apart is not some quicky "oil Change" type of thing.
here is what I would do if I were you:
If money is THAT tight, that you can not afford all of the parts necessary to do a rebuild right...take it easy on teh tranny, try not to shift it hard/abuse it, and save some money, buy some parts here/there, and THEN do teh rebuild.
But, one more time though.....it DOES HAPPEN ONLY IN 3RD GEAR, right?
Old Jul 25, 2009 | 04:44 PM
Gen414's Avatar
One more thing...try this....Pennzoil Synchromesh (hard to find) tranny fluid. It is a little bit thicker tranny fluid, and MAY help the shifting some if not too bad.
There have been quite a few people that have used it here on teh site with success, and might be worth a shot at this point before you try to rebuild it, ya know?
The only experience I have with teh Pennzoil Synchromesh is in my Cummins NV5600 6 speed manual tranny.
Might want to do a search on it here in teh forum, but I do know that some have used it and like it.
Old Jul 25, 2009 | 05:06 PM
therobman's Avatar
they sell the syncormesh at autozone i switched and i love it
Old Jul 25, 2009 | 05:27 PM
BLKNRDPREDATOR2001's Avatar
I had the same problem too, i had broken the 3-4 shift fork. Like GEN 414 if its too expensive for you just replace the 3-4 shift fork with a steel one and replace the synchro blocking rings while your at it. I did this without knowing how to rebuild a t56 but thats what i did to save money. Its been 3 years and now that i have a 383 stroker its still going without no problems. Take time and check everything if your gonna drop your tranny, check your master clutch cylinder, slave cylinder and hydraulic line throw out bearing. Just a thought, Good luck man
Old Jul 26, 2009 | 01:18 AM
onebadZ28's Avatar
thanks for all the help guys i really appreciate it. yes the tranny only grinds shifting from 2nd to 3rd gear high rpms only. really strange considering it was grinding 1st thru 4th and maybe even 5th and 6th i don't know didn't make it that far lol. As far as the rebuild goes i have the money to do it i was just wanting a monster clutch instead. the car is not a daily driver so i'm not hard pressed to get it back on the road right this minute so that is a good thing.
Old Jul 26, 2009 | 09:49 AM
Gen414's Avatar
I wanted to show some pics of a tranny I opened up teh day before yesterday. Customer tranny, was not really having any problems with it, just time to strengthen it up some. This tranny was rebuilt less than 5K miles ago by another company
This will give you an idea of a "damaged fork pad"
"Gunk" (again, less than 5K miles)
Mainshaft:
