trans making funny noise
i just finished in stalling an 02 camaro 6 speed in my 95 s10. when i bought it the guy said it had been gone through and everything looked good. after i finished getting is in i began to go through the gears and everything worked fine till i put it in reverse. when i went to take it out it came out of reverse but the shifter was stuck. anyways i took the trans apart only to find that the revers shift rod was bent. after replacing the rod i put everything back together. i drove the truck for like 2 days, got on it a few times and one day when i let the clutch out it made a funny noise. when i let the clutch out it make kind of a winding noise for a split second and it goes away. i have had a few t-5s in the truck and the gears start to howl before they blow, but this noise doesnt sound like that. do you think there is something wrong with it? i took it back out because i thought it was the pilot bushing but that all looks good. is there something wrong with the trans?
