Driveshaft was gone!!!
Old Nov 27, 2003 | 02:45 AM
fastsspr's Avatar
Unhappy Driveshaft was gone!!!
Last week i plan to do my first trip to the 1/4 mile so put my nittos on the can and tried them on the street.Broke my posi unit in the first burnout .Ok fits the posi and plan to go to the track today wednesday 26.I make ritual first put the tire pressure to 20psi statrt the burnout in 2nd gear,them a clean up at 3000rpm the car felt real good like it going to do some 1.8s.When was in the starting like rev to 4k to lunch the car.When i lunched it twisted and broke driveshaft real bad SO no 1/4times today to .
Now wich driveshaft are you using?
Old Nov 27, 2003 | 06:05 AM
4thGENRETARD's Avatar
Typical M6 dilema, unloading that clutch at those rpms will do that. Sorry man. Try Lingenfelter 3.5 inch aluminum, balanced to 10.000 rpm and one strong Mama.
Old Nov 27, 2003 | 11:05 AM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Just have a local driveline shop build you a 3.5 inch steel driveshaft with a 1350 yoke and spicer u joints. I had one in my car and it held with 7K RPM launches on slicks. I sold it about two years ago along with the 12 bolt and the guy still has it in his car.
3.5" Steel Driveshaft + 1350 yoke and spicer u joints = Bomb Proof!!
Old Nov 28, 2003 | 02:17 AM
blueWS6's Avatar
wouldnt that be a bit heavy cause i know the lingenfelter one doesnt weight that much and its strong as hell
Old Nov 28, 2003 | 03:03 AM
Jason99T/A's Avatar
I can shift faster than you.
I had a 3.5" aluminum driveshaft in mine built by a local driveline shop and it held to everything I could throw at it. The good part was it weighed only 0.5 lbs heavier than the stock DS.
Old Nov 30, 2003 | 12:54 AM
fastsspr's Avatar
Any of you have Denny's shaft on your car?
If you have it are you experimenting vibrations?
I just have to by one ASAP!!!thanks
Old Nov 30, 2003 | 07:45 AM
Gimp98TNT's Avatar
I've got Denny's nitrous ready DS. I couldn't be happier with it. No vibrations.
If i were to do it again i problably spent the extra 100$ and got the aluminium one.
