Synchronizer?
Old Sep 7, 2009 | 03:54 AM
Brian'sCharlotte(TA)'s Avatar
Default Synchronizer?
I can shift fine in all of the gears however, when i'm at the track or just driving the car fast I have problems with fourth gear. When I put it in it will either:
A. POP out of gear or
B. violently shake and vibrate when it is in gear...
when driving normally there is no problem with it but it gets very touchy under WOT. I'm lost.. Someone help me.
OO! Forgot to mention that I have replaced my shifter with one out of a GTO that is signifigantly shorter however slightly hits the console. My friend suggested that it is just hitting the console and not going in all the way and popping out but.. I dont know
Old Sep 7, 2009 | 08:36 AM
Gen414's Avatar
Sounds like he is right...hitting console, and also...does it have stops on it? I BELIEVE teh GTO shifter has shifter stops built into it, so make sure those are adjusted ( I could be wrong on that, as I am not real familiar with teh GTO shifter...)
Old Sep 7, 2009 | 11:59 AM
Well I just swapped the sticks.. Not the entire thing. I got the stick for free and it looked cool so I just switched them. I'm pretty knowledgeless on transmission dealings
Old Sep 8, 2009 | 08:31 AM
Gen414's Avatar
Originally Posted by Brian'sCharlotte(TA)
Well I just swapped the sticks.. Not the entire thing. I got the stick for free and it looked cool so I just switched them. :
Not sure what you mean??? You swapped sticks back to your original, same problem? Or, problem fixed? Or???
Old Sep 8, 2009 | 02:43 PM
haha no, when I put in the gto shifter i just installed the stick, not the entire mechanism
Old Sep 8, 2009 | 03:01 PM
Gen414's Avatar
Oh ok...and the problem came about after the shifter?? If so, put the old shifter back on and see what happens.
Old Sep 8, 2009 | 04:51 PM
Well, it still vibrates a little. No popping out from what I tested but under high strain it seemed to vibrate a little bit more than normal.
Old Sep 19, 2009 | 09:32 PM
Ok, well i've been driving the car for a while and no change from the shorter stick. I guess I need to replace my Synchros? Any suggestions on how to do this? Shop or learn how and do it?
