Hard to get in gear
You asked earlier, and I didn't see it til now, but I am not running a Tick master. I'm running out of options and I'm tired of driving my truck to work in this nice fall weather. Did swapping the master help?
I am having similar troubles with gear engagement as well with the car running. A little back round:
Had the car apart to rebuild the motor and removed both engine and tranny. I didnt mess with the hydraulics at all, just unplugged the quick connect on the slave.
I purchased a new GM slave to go into the transmission and didnt do anything to it other then bolt it to the tranny with the new TO bearing. I really didnt know if there were any procedures / bench bleed process for it
and figured that since the hydraulic system is a closed system, that any air would be removed during traditional bleeding.
We did the traditional two man bleeding and relieved most/all of the air out of the system and the tranny engaged all gears perfectly.
One day driving around I had some 2010 camaro messing with me so I had a few spirited miles just driving and a little racing. During that time my clutch pedal started to stick to the floor a few times at WOT. But still drove normal and shifted fine.
With that happening I figured there was a small amount of air in the system so I purchased a Mity Vac and pulled vacuum through the reservoir. Several small air bubbles came through the line, I did this several times until there were no more bubbles.
Well after doing that with the Mity Vac I hopped in the car and now the car wont go into any gear while running with the clutch pressed. It has normal pedal pressure. I tried the mity vac several more times last night and its the same deal, some bubbles at first and then none and still no engagement.
My main question is that I am confused about cracking the bleeder screw while pulling vacuum to the reservoir. Wouldn't that allow air into the system? I think I may be reading your statement incorrectly by "opening both ends". And believe you are saying to do it separately and not at the same time.
Any suggestions to my situation? I think I may just have someone help me and do the two man bleeding again. The clutch is a stock ls6 clutch and the tranny has about 55k miles. Unsure of the mileage on the clutch but I'd guess around 3-5k from the way it looked.
Any help will be appreciated. I have searched this topic for a while (about a week) and this is the first post that I have replied to since it best fits my situation.
You might have damaged your MC. I am amazed tick hasn't posted on this. I have read before that they prefer you not to use a mightyvac on there mc's and if you do not to go over 10hg/in.
If you get the chance to pull the clutch out you can assemble the clutch to the flywheel and test it on a bench press.
Have you cooked the fluid before??? If your fluid was black at any time you could have boiled it and have some restrictions in the line.
Yes I have cooked the fluid before. I bought it and drove it then changed the fluid after driving it on the track, local meets and on the highway. It was black when I changed it. I dont think it was ever changed the whole time the other person had it.
So it would just be a restriction in the line then? I dont want to buy another master and have it be the brand new slave I just put in. Pedal pressure is fine but I guess that doesnt necessarily mean their couldnt be a restriction.
Pedal still sticking to the floor at all?
If you push the pedal in can you see fluid come into the reservoir?
have you done the drillout mod?
I am guessing u probably have a master issue due to the fact you just put a new slave in.
Or your bleeding the car wrong and are letting air into the system somehow.
I dont think I am bleeding it wrong. Push pedal to the floor, crack bleeder, let air/fluid come out, close bleeder. Bring pedal up slowly, push down pedal, crack bleeder again and repeat till pedal pressure comes back.
I think I might just bite the bullet and get the Tick master. I dont want to get another stock one and have the same **** happen.
Thanks for the help
