Harlan Shift Light Help
Old Sep 14, 2009 | 08:42 PM
MetallicaMatt's Avatar
Default Harlan Shift Light Help
This is an epic fail for me
ALL of the wiring i've done over the years...and I can't get a 3 wire shift light to work for me lol
sodered all the connections, 12v keyed, ground and white #10 from the pcm...programmed it (yes in 4 cylinder mode) and set the rpms
everything flashed back correctly but when i got to the rpms to test it, nada, nothing, zip
Can i take my 12V test light to the tach wire to see if it's getting power AT the shifter, or will i fry it?
i haven't a clue why it isn't working, the wire isn't busted or anything. Ran an 18g wire from the PCM to the light, heavier than what was supplied, but still light in my opinion.
Things to try?
Connect to something else? if so, what? and how to program - i.e. change modes on the light?
Old Sep 14, 2009 | 09:21 PM
1BADAIR's Avatar
what wire did you hook it too?
what year car?
Old Sep 14, 2009 | 09:24 PM
2002 trans am
green wire from the shift light went to lower (red) pcm, pin #10, white wire
Old Sep 15, 2009 | 11:27 AM
nobody?
I can't get Harlan to reply, even PM'ed him on here
Old Sep 15, 2009 | 11:49 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Can you take a picture of the wire you tapped on the PCM side?
Old Sep 15, 2009 | 11:57 AM
I can, but I am 100% positive it is the correct wire.
It's on the "red" PCM which is on the bottom of the two. pulled the plastic cover off, found pin #10, which was a white wire, per the directions, spliced into that
Only thing I can think to try, that wouldn't chance frying the light would be to test the voltage at the splice and then at the light....
Old Sep 15, 2009 | 04:04 PM
MeentSS02's Avatar
IIRC, the wire I tapped was white (but it has been a LONG time ago), so it sounds like you got the right wire. Provided the tap is actually making contact with the copper wire and not just the insulation (I've had it happen to me before), I wouldn't know what else to check. As long as it is set to 4-cyl, and you are obviously getting good power and ground since you are able to program it, that is the only thing missing in this equation.
What kind of tap are you using?
Old Sep 15, 2009 | 07:26 PM
I'm not using a tap, I soder all of my electrical connections
Old Sep 15, 2009 | 09:43 PM
MeentSS02's Avatar
Well, put a multi-meter to the soldered connection at the PCM and ground the meter to wherever and see if you get a voltage output with the engine off, and then with it running.
Old Sep 17, 2009 | 10:17 AM
tach is getting power at the shift light, no idea what's wrong
Old Sep 20, 2009 | 12:58 PM
Harlan hardly ever gets on here anymore, so I'm not getting much help from him
can I tap into something else???
Old Sep 30, 2009 | 01:09 PM
1Loudz28's Avatar
pretty sure you want it in 8clyn mode...
installuniversity.com has a good write up on how to do it
sounds like your wiring is correct since it flashes back, but i think you have it on the wrong mode...
Old Sep 30, 2009 | 01:44 PM
taws6m6's Avatar
NO, it goes in 4cyl mode. You know the light has power since it flashed back to you. Really sounds like there is something wrong with the tach signal from the pcm. Thats where my bet is
Old Sep 30, 2009 | 04:59 PM
1Loudz28's Avatar
weird. i have a harlan, and i followed install universitys instructions, put it in 8cyl mode and it works flawlessly
Old Sep 30, 2009 | 11:35 PM
SnakeStomper's Avatar
why 4? I have mine set to 8cyl too, I have a V8
Old Oct 1, 2009 | 07:15 AM
Our engines send 2 pulses per rev, so it's set to 4 cyl. mode...or something similar like that.
I believe it'll work on 4 and 8 cyl. mode, just is more 'accurate' in 4 cyl. I'm sure the difference isn't anything that we could ever notice
Harlan's an electrical guy, you know how those guys are
Still a stand up guy, he drove to my house to check out my light, can't be more happy!
Old Oct 1, 2009 | 03:41 PM
Grifter's Avatar
So what was wrong with it?
Old Oct 1, 2009 | 10:53 PM
unit was fine, when I did the final shrink wrap over all 3 wires, i slightly melted the inside shrink wrap, to where just 1 strand of wire was sticking out of the ground and tach, so the tach signal was grounding out
Old Jul 23, 2013 | 12:54 PM
Rise of the Phoenix's Avatar
I just ordered mine and already printed out the install directions off of installuniversity. My question is this; If I want to mount the shift light on the driver's side A-pillar in the defrost vent, can I follow those directions, or is there another write-up somewhere more specific to installing the shift light there?
Old Jul 23, 2013 | 01:08 PM
Guitar's Avatar
It's pretty simple to install it there. Do what they say as far as running it to the ecu and such. I just ran my wire to the side power and stuck it in one of the fuse areas instead of doing what they said. Works fine.
