Clutch Dragging?
I'm not from the Podunk so I know what an Internal Slave is..I've seen a couple..
New LS7 PP / Clutch - 0 miles (I torqued the PP down in cris-cross pattern in 5 passes)
New Slave - 0 miles
New Tick Adjustable Master - 0 miles
Still hard to get in gear.
Here are the only things it could be:
1. Bleed more (You got to be kidding me)
2. Needs a shim (Why would the clutch work for 3k miles and then, out of nowhere, need a shim?)
3. Transmission itself. (Not likely)
Does anyone have any suggestions before this car ends up being on of those barn finds in 40 years?
The first time I put in the LS7 PP/Clutch back in April it would engage right off the floor for the first 50 or so miles. It surprised me yesterday when I had to let the clutch pedal up a long ways before it would engage.
It's got to be 1 of 2 things - air in the system or I didn't torque down the PP evenly. I did all passes in cris-cross pattern: snugged the bolts down, then 13 ftlbs, 26ftlbs, 39ftlbs, and last pass 52ftlbs. Was that not good enough?
The thing that is bothering me is - why is it going into gear smooth as butter if I hold the clutch in for a couple of seconds? And why can I quick shift it 1>2, 2>3, etc without any problems?
