Tring to blead clutch: Please Help
Old 09-27-2009, 08:30 PM
355 RS's Avatar
Default Tring to blead clutch: Please Help
I just got my clutch bak in and my dad and me took the car for a ride. It felt good but if i cracked down on it real hard and then go to shift it would hang a little like the clutch wasnt fully disengaged. So i followed the instructions on bleeding it from this site which i found on thirdgen.org(http://www.teamrip.com/how_to_proper...utch_info.html). I tried bleeding at least 18 times but it kept getting worse no better. Now its so bad you cant even start while in gear because even with the clutch fully depressed it trys to take off. Am i doing something wrong? Is my slave or master cylinder bad? Please, any help is appreciated. Thanks
Quick Reply: Tring to blead clutch: Please Help
