ls7 clutch issues
Old Nov 10, 2009 | 01:41 PM
  #41
tillery's Avatar
LMFAO- your right-its called Midland cause its Midway between dallas and el-paso. Aint crap out here but oil fields and ******. Well at least over here in Odessa.
Old Nov 10, 2009 | 01:47 PM
  #42
bearcatt's Avatar
Nothing wrong with that. Reminds me of that show "Black-Gold" .
They didn't show any ****** though.
Old Nov 10, 2009 | 03:48 PM
  #43
rabiddog's Avatar
Originally Posted by tillery
Maybe clutch installed backwards?
I am going to act like I never read this comment!!!
Old Nov 10, 2009 | 03:50 PM
  #44
rabiddog's Avatar
Oh and Bearcatt- Midland is nowhere near the gulfcoast-lol. but we have gotten some coller weather out here cause of that storm. what are you doing today? after 1 I should be free to swing over to midland. Beaches? is that what we calling them now?
beaches desert whatever!!!
I am in crane at the moment. I wont get home from work till about 6:30. You are more than welcome to come by and look at it. I would love to bring it to odessa but... yeah...
Also I HAVE PIC'S!!! They are at the house though. I will post them when I get to the casa. Thats about 60 miles of beach away... just for you bearcat
Old Nov 10, 2009 | 04:52 PM
  #45
haighter's Avatar
If you are using this in a F-body... You need to use a ls2 flywheel not an ls7. You need to look into that.
Old Nov 10, 2009 | 05:32 PM
  #46
bearcatt's Avatar
Old Nov 10, 2009 | 07:59 PM
  #47
bearcatt's Avatar
In a crane at the moment and being online at the same time.
hmmm interesting.
Is this a oil rig crane ?
Is it a real tall crane ?
Sorry about all the questions.
Cool, I can have a virtual vacation with pictures.
Old Nov 10, 2009 | 09:26 PM
  #48
tillery's Avatar
You were right bearcatt about the pressure plate needing adjustment. Comparing the stock one and the new one we saw what you were explaining. Crane is small town south of middle of nowhere.
Old Nov 10, 2009 | 09:35 PM
  #49
bearcatt's Avatar
I should have known about the correct Crane . lol
http://maps.google.com/maps?hl=en&so...ed=0CAgQ8gEwAA
Most of the time they should be preadjusted, once in a while they could be out of adjustment from shipping and handling.
Old Nov 11, 2009 | 12:32 PM
  #50
rabiddog's Avatar
ALRIGHT!!! maybe!!!
I got with a local tranny shop and he is willing to let me use his bench press to try and adjust the pressure plate probably wont be till tuesday befor I can get in early enough to give here a shot.
PICS!!!! for who wanted them.
PS I have looked into ls7 and ls2 flywheels. It doesn't matter. Even the dealership will tell you they are the same flywheel.
Tillery thanks for all your help I mityvaced that slave for a while no air anywhere after that first little bit. Hope you dont get stuck out on that job for too long.
Old Nov 11, 2009 | 12:44 PM
  #51
rabiddog's Avatar
off the topic but I almost forgot this part of the car was still in there. It's been a while!!!
Also just wanted to add again the clutch wasn't in backwards...
Old Nov 11, 2009 | 01:02 PM
  #52
SPEC-01's Avatar
Can you repost the pics or check the links because all I get is X's. Let me know if you have any questions about the resetting of the SAC mechanism. Thanks,
Old Nov 11, 2009 | 01:04 PM
  #53
tillery's Avatar
Funny you should say that-the injector beams got chewed up by the chains-rebuilding them right now. Did they guy from Spec send you a way to adjust the clutch?
Old Nov 11, 2009 | 01:17 PM
  #54
bearcatt's Avatar
rabiddog,
It appears that your clutch is ok on the factory adjustment.
That's how LS7 clutches are supposed to look.
All the other LS7 clutches ( including mine ) I've seen look like yours
What to do next ...
This is getting crazy, you are very patient.
Try putting the stock slave bleeder back in.
Forget the Tick speed bleeder for now.
I've read a couple of cases about those speed bleeders letting in air.
I didn't use it, more problem then it was worth to me,
now on a Corvette that would be a different story.
Back the peddle adjustment out on the Tick m/c a bit.
Try, in effect doing a bench bleed with everything still
on the car before putting the tranny back in.
Do a gravity bleed first and than an easy peddle bleed.
This way you can get all the air out.
Also just for ***** and giggle why not check for freeplay.
http://www.ramclutches.com/Tech/Tech...%20Bearing.jpg
I hope this all makes sense because there can only be so much wrong.
Other than a defective pressure plate, (not likely) but it has happened
to others in the past.
Last edited by bearcatt; Nov 11, 2009 at 01:29 PM. Reason: because my spelling sucks
Old Nov 11, 2009 | 02:07 PM
  #55
rabiddog's Avatar
http://i637.photobucket.com/albums/u...5/stuff002.jpg
http://i637.photobucket.com/albums/u...5/stuff001.jpg
http://i637.photobucket.com/albums/u...5/stuff034.jpg
here is a few of the pics if you just click the link
Old Nov 11, 2009 | 02:09 PM
  #56
rabiddog's Avatar
ok I am going to get w/ the parts house that I bought it from and see if they can just get me another p/p. we'll see what they say. If I have to pester the living crap out of them for a month I will get the SOB.
Old Nov 11, 2009 | 02:32 PM
  #57
rabiddog's Avatar
That sucks man I would say starting off like that I would just take that big *** unit back to the yard.
Not from spec yet but I did get the procedure(well I am pretty sure its the way its done) post from bearcat
Old Nov 12, 2009 | 06:55 PM
  #58
rabiddog's Avatar
ok well I am getting the run around from the parts house at the local chevy dealership!!!!
Old Nov 12, 2009 | 08:28 PM
  #59
bearcatt's Avatar
https://ls1tech.com/forums/12493111-post54.html
Old Nov 12, 2009 | 08:31 PM
  #60
bearcatt's Avatar
rabiddog,
Did you read this post ?
