Did the rev test and need some answers.
OK I did the rev test today at the track. The car started to move around 4,600 rpm's. He is my set up.
-Textrilla oz700
-Stock M/C with drill mod
-2nd time around built T-56
-DOT 4 brake fliud
I cannot powershift the car at all. I bleeded the clutch Friday night for 30ish min's using GEN414 method. It stills is releasing about an 1" of the floor board. I even bleed it at the tracked and help out again. But it is still releasing an 1" of the floor board.![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
So here are my question for you guys.
-Tick said the Tex don't need a shim, but according to the rev test I need one, what do you guys think.
-What should I do to try to fix this.
I have been having this problems since April of 08' and I'm now starting to figure it out. I would always be missing gears and I thought it was me but I know now its not. The clutch has always release an 1" of the floor board. Any help would be f**king awesome.
I ran my new personal best to day at the track with the f-ed up clutch 11.80 @ 116 w/1.59 60'. I couldn't believe I did a 1.59 60' with a six speed and 28x11.5x16 MT et street II![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks
-Textrilla oz700
-DOT 4 brake fliud
Thanks
OK, well could be a couple things...one, need a shim. Did you measure?
How OLD is your MC?
What about slave?
Could be a PP, but if setup is new, would be inclined to look at teh above 3 first.
How OLD is your MC?
What about slave?
My
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
The slave is 1.5 years old.
The clutch is also 1.5 years old.
I have a tilton 5.5" triple disc clutch with a stock master that is 8 years old and a qtr master hydrylic release bearing. Ever since I stopped using a replacement style clutch I have'nt failed a "rev test". Tick wants to sell a m/c.... I don't want to sell him anything but I did work on race cars for 17 yrs and trust me It's the pp. All you guys keep throughing parts at this problem and bleedin your system. I haven't bled mine for years. All I do is replace my discs when there wore out. If your hydrolics are bad they will let you know just like any thing else that holds fluid....... They'll leak.
