clutch problem
"The pressure spring of the pressure plate in the clutch comes out (means back directionaly to the gearbox) if the friction plate loses material while using.
The hydraulic throwout bearing has to move back to compensate this back moving of the spring ... then everything will be fine to the point, where the friction plate has reached the "life end". This is normal.
But with your setup the throwout bearing can move only 3 mm back, this is to short ... after a short time of using the clutch the bearing will stuck on the mounting surface of the gearbox, the clutch will never fully engage at this point, starting to be slippy. Normal the throwout bearing needs 11 to 12 mm for backmovement for compensating."
This is a SPEC 3+ clutch that was in the car after the conversion, but it wore out after 9K miles. Maybe it wore out early because of this? I've been driving on an LS7 clutch until the 2nd engine was purchased and now I'm going back to the SPEC 3+.
Any ideas on what needs to be done? The mechanic has been calling SPEC, but he still doesn't know what to do.
That being said if you are dealing with Andy @ Dany's Garage he seems to be doing a great job with assessing your issue. Last time I emailed with him it seemed that your transmission has been faced at some point (which would chang the depth). All of the parts measurements were within spec and thus this doesn't appear to be a parts issue. Let me know if you have any further questions and I will be happy to assist you further. Thanks!
