Ever had problems with your black clutch peddle switch?
This morning I go to start the car and there was a 2 second delay when you turn the key and then the engine fires. This has never happend before. Then I go to work and the car will not start. I have power and the security system is not armed. I try again and it starts.
Anyone had problems with the small black clutch peddle switch under the dash? This is the only thing I would think it would be.
Have the same issue every once in a while.
If I turn the key back to the off position after this happens, my security light stays on for approx 2 minutes.
After the light goes off, I can start the car fine.
I always assumed this was the VATS system being flakey.
They're only a couple bucks. I had a similar problem as you for a while. Thought it was that switch so I replaced it but it persisted. Turned out to be the starter SLOWLY going. Eventually left me stranded. Replaced the starter, no issues since then (that was over a year ago). It took me a WHILE to figure out what this problem was because all the symptoms pointed to an electrical issue and it was intermittent, but whacking the starter never worked like it usually does with other cars I've seen. Just something to keep in mind if your problem doesn't go away with swapping the switch.
It's not too difficult, but I guess that's all relative to your experience with working on cars.
