What does the reverse light plug on a T56 go into?
I need to find the source of the two wires that plug into the T56 so I can get my reverse lights working.
Splaulsen, so are you saying that the plug for the reverse lights actually comes from the PCM? Do you know what pins on the pcm correspond to the plug? I tried looking at a PCM pinout and didn't see anything that had to do with the reverse lights. If that's the case then I should be able to run new wires from the pcm to get my reverse lights hooked up.
im gonna trace those wires and see where they go and ill let you know soon.
My guess is the switch on the T56 is an old-school switch that closes the circuit to turn on the back-up lamps directly.
Lots of guys have done this swap that can either confirm this or set it straight.
[/IMG]on that plug it it the second and third wires...im gonna check my car to see if these wires are in the same location for the other side of the plug...
I can't find a plug on the M6 engine harness that goes to the reverse lights.
Is the reverse light plug not part of the engine harness, but integrated into a body/chassis harness instead?
