Preferred fluid for T56?
Old Oct 28, 2009 | 07:39 PM
wannafbody's Avatar
Default Preferred fluid for T56?
What is the current preferred fluid for the T56? In the past I believe it was either Synchromesh or M1 ATF.
Old Oct 28, 2009 | 08:17 PM
Chris05ssTruck's Avatar
I have used Red Line for awhile....works great for me and others i know who have used it.
Old Oct 28, 2009 | 10:26 PM
slayerized6's Avatar
dexron III is the owners manual recommended fluid.
i prefer dex3 over Pennzoil snychromesh though. havent tried anything else
Old Oct 29, 2009 | 08:13 AM
PewterScreaminMach's Avatar
Dex III is GM recommended. A lot of people use Mobil 1 ATF, some use Redline, Royal Purple, Pennzoil Synchromesh. You'll hear a lot of people say good and bad things about most of them depending on who you talk to. If you just want to be "safe", best option is probably to just go with Dex III per GM's recommendation.
Old Oct 29, 2009 | 08:42 AM
getusum's Avatar
You want the best? Or, the most commonly used.....It's all a matter of oppinion...2 qts mobil 1 and 2 qts Synergyn is as good as it gets....Synergyn is very very pricey...
Old Oct 29, 2009 | 12:39 PM
XtremeDime's Avatar
i have royal purple with syncromesh
Old Oct 29, 2009 | 01:06 PM
99Z2ate's Avatar
I used RP sychromax and I could never get the trans back into 1st gear. It would just grind unless I came to a stop. I have since used RP ATF and it shifts like butter
Old Oct 29, 2009 | 01:13 PM
ws6pewter's Avatar
When I changed to Pennzoil Synchromesh I did not notice any difference at all. I have not tried anything else and probably will not and when it comes time for another fluid change I'll probably go back to Dex III
