stupid clutch questions
I'll keep this to the point. I need a new clutch. How much would the install be (ballpark)? Is it worth it to upgrade the clutch or should I stick with a new stock one? Car is lightly modded and is a daily driver, doesn't see the track and won't for a few years probably.
Might try the McLeod single disc. Not too bad on the pocket book and still handles over what is stock. DIY probably around $350 for parts. A shop... 250-500 for labor.... ish.
Or you could just go with an LS7 clutch kit.
