shifter rattles sometimes while driving
Old Nov 8, 2009 | 08:55 AM
Krypnosis's Avatar
Default shifter rattles sometimes while driving
My shifter is rattling while I drive sometimes and I think it's because there is a little play in the stick even though it's in gear. What can I do to get rid of that noise or is it something I have to live with?
Old Nov 8, 2009 | 12:35 PM
slayerized6's Avatar
tighten the stick, tighten shifter.
Old Nov 8, 2009 | 01:08 PM
MeentSS02's Avatar
Kleeborp the Moderator™
It would help if you told us what kind of shifter it was - some are more prone to noise than others.
Old Nov 8, 2009 | 10:18 PM
the_merv's Avatar
Veteran: Air Force
Bronze Shifter Bushing.
Old Nov 8, 2009 | 11:34 PM
haighter's Avatar
Do you have a stock shifter or an after market one? If its stock or after market sure that the base is tight to the trans and that the stick is tight to the base of the shifter. Also the plastic bushing that is the trans that holds the shifter can break or go bad. Upgrade to a new bronze one if you abuse your tans or slam it into gears with a stock shifter. If you have an after market one and it has limiting bolts make sure they are tight.
Old Nov 9, 2009 | 12:09 AM
KW4life06's Avatar
I think I may be having this same problem. Who makes the bronze bushing?
Old Nov 9, 2009 | 01:10 AM
therobman's Avatar
mine rattles like a pig at idle but then again my hole car shakes because of the cam lol. call tick performance thats where i got mine
Old Nov 9, 2009 | 01:22 PM
the_merv's Avatar
Veteran: Air Force
Several people sell them.
Old Nov 9, 2009 | 05:03 PM
haighter's Avatar
D&D, RPM, the gear box... Most t56 places will have them.
Old Nov 9, 2009 | 09:15 PM
KW4life06's Avatar
could that be where fluid is coming up through too? Had my shifter off and had some fluid that had sprayed up inside the rubber boot. Smells like tranny fluid after taking it in the higher rpms too
Old Nov 9, 2009 | 10:17 PM
the_merv's Avatar
Veteran: Air Force
I'd be suprised if you have a T56 and Fluid is spraying everywhere..
Old Nov 9, 2009 | 10:42 PM
haighter's Avatar
Off the shifter boot or the boot for the senter console? It is often that you will see it on the bottom of the console boot from the tunnel. That is caused when you have a bad seal in your tail housing of the trans or if you have a drive shaft that is not ballanced well. It causes the trans fluid to be flug on all the sides of the tunnel from the yoke of the drive shaft. Or it is caused by over filling. The t56 take about 2.6-2.8 quarts of ATF.
Old Nov 10, 2009 | 09:50 AM
CaliboyTA's Avatar
my stock hurst rattled like crazy. almost sounded like loose change vibrating. it ended being the shifter being too warned out, and had tons of play. i ended up getting the pro-5.0 and the sound went away.
