gto slave and master in a f-body
The slave is the same part (same GM PN) with a different fitting. Don't know if the master will fit or not, but it does have a much larger bore than the F-body. Only problem is, they aren't any cheaper that the Tick M/C. All of us GTO guys are getting the F-body slave and changing the fitting because it is so much cheaper.
i know the slave is the same minus the fitting. i am going to swap a guy my 6 speed stuff for his th 400 set up. so i am wondering if it will work in his car so that we can make the swap and beable to use the parts without having to buy new parts
I answered this on the gto forums. The master will not work, the slave needs the quick disconnect fitting. Get a Tick master and the only thing you will be missing is the fitting on the slave.
