Reverse lockout operation.
My problem is that the reverse lockout doesn't disengage because it's not recieving ground from the PCM.
It turned out the PCM I got is for an automatic and I already used 4 HPT credits for that PCM 2 of which are for the custom OS.
I have no clutch anticipate switch and not sure if that is required for the reverse lockout to operate as it should.
