T56's 5th gear 1:1
Cannot be done. Also why would you want to? The 1:1 ratio is acheived when the input shaft and the main output shaft is coupled together (this is the only gear that the cluster gear is not being used to transmit torque).
In-Zane Moderator
Richmond offers the Richmond 6 speed with a 5th gear of 1 to 1 and 6th has OG.
http://www.jegs.com/i/Richmond+Gear/...626AA/10002/-1
# 6-Speed Overdrive Transmission26-spline input
# Gear Ratios 1st to 6th:
3.28, 2.14, 1.57, 1.24, 1.00, .76
The Richmond 5+1 is designed that way specifically. The input shaft sticking out the front of the unit is 5th gear so its basically the same thing as 4th gear on the T56. Instead of having a 2.66 1st gear in the T56 with a lower rear end ratio, Richmond decided to make 1st gear a little lower and recommends that you use a higher gear ratio in the rear end. Instead of splitting the difference from 1st gear to the 1.00-1 rato by 4 like the T56 does, Richmond splits it by 5.
I'd like one more gear for drag racing without having to swap out the rear gears for something lower numerically. I've been looking for a 5th 1:1 tranny, but don't know if the richmond/D-N/Gforce tranny's will bolt in and how much mod will have to be done to get their shifters in the same relative position in the tranny tunnel.
You are kidding, right? You want to see if you can spend few thousand dollors for a Richmond trans just so you can get the 1:1 5th gear when you can just replace the rear gears for much less? Not to metion what mods you have to do to make that trans to fit. I don't get it........
I hadn't been able to find any info on the 5th gear 1:1 so it looks like I found the answer I didn't want to come to grips with.
Depending on the engine combo and if there is a power adder, it sounds to me like you need less gear not more. I run a 3.73 gear in my car with a 28" tire and cross the traps at about 6300 rpms on the motor. I plan to put a 100 shot on it so it should be ideal with my tire size and gear ratio. If you are trapping high 130's right now and want to make it go faster, add more power and take a little bit of gear out of the diff but keep the big tire.
Yes, no sense in having 4th and 5th at both 1:1. If 5th could have been 1:1, I would have put 4th as 1.15-1.3:1
Maybe Im missing something but if your saying you are getting close to the limiter through the traps, how is having 5th as 1:1 going to help anything?
4th gear is 1:1 right now, so making 5th gear 1:1 is going to do nothing other than giving you one more gear to shift.
LS1TECH Sponsor
Theres absolutely no reason to have some kinda close ratio tranny with a 5th gear ratio of 1:1. If you want to change gears an extra time, just cram a ton of gear outback and go to the 5th gear you already have lol. I used to run 4.56's in a car that I didn't want to turn past 6800 rpms because I usually ran 1/8 mile. When I'd go to the 1/4 I'd shift to 5th gear at about 120 mph and cruise till it crossed the traps at around 130mph. Of course it would have been faster with a 4.10 gear in the rear for the 1/4...
