Reverse lock-out?
Old Nov 19, 2009 | 03:57 PM
1 Craz28's Avatar
Default Reverse lock-out?
How come when I drive my car reverse is not locked out? I noticed the other day it actually tried to go into reverse while driving? Could it be the tune I just received?
Old Nov 19, 2009 | 08:20 PM
Spartan7's Avatar
Take the solenoid off and see if the plunger is extended or not. Then apply 12v to it and see if the plunger moves. If it doesn't, it's bad. It should be extended all the way out with no voltage, and should move inward (towards the solenoid) with voltage.
Old Nov 20, 2009 | 10:27 AM
the_merv's Avatar
Veteran: Air Force
Is it wired in correctly?
Old Nov 20, 2009 | 04:39 PM
1 Craz28's Avatar
Wired in? It's factory, it just started doing it, I will check plunger and trace the wire!
Thanks
