Bleeding Question
Old Dec 16, 2009 | 09:42 AM
BLUEBYU's Avatar
Default Bleeding Question
Waiting on engine to be completed and thinking I can "bench" bleed the master while on the car? Can I connect the slave and then connect a vaccuum line to the bleeder valve to accomplish this? I have a reservoir I can place between the vaccuum and valve to inspect fluid for bubbles. Once this is done I should be able to install slave prior to mounting tranny? I have a Mcleod master.
Old Dec 16, 2009 | 01:41 PM
KCFormula's Avatar
I would think it would be a huge PITA to do it with the master still in the car. If you have the motor out taking the master out should only take about 10-15min and I think bleeding the system outside the car would do a much better job as well.
Old Dec 16, 2009 | 01:44 PM
BLUEBYU's Avatar
Thanks. I had this master installed by someone else... should be on How-to... Install U?
Old Dec 16, 2009 | 02:01 PM
KCFormula's Avatar
Its pretty easy man. There is one "U" shaped bolt holding it on from the engine bay side and then two nuts attach it down by the pedals.
-Take the pannel under the column off. (the one that houses the hatch release on hatch cars)
-Use a screw driver to pull the clip off the clutch pedal
-Unbolt the two nuts from the firewall and it should come right out.
PM me if you have any problems Randy.
